View unanswered posts | View active topics It is currently 06 Nov 2026, 08:35
Lovepedal Eternity Kanji Handwired
Post Lovepedal Eternity Kanji Handwired
Säljes i befintligt skick.
1500:-
Kopierad text från hemsidan:
The sound: this pedal is amazing, straight up. Firstly, it’s not completely transparent; it adds a slightly mid-humped, very warm character to your tone. I stress, very warm. The Kanji is probably best described as a low to medium gain overdrive; however, cranked up in front of a tube amp, this thing has gigantic balls, so you might even find yourself backing off on the Drive a bit. I usually tweak starting with the Level knob, as I believe it has the most influence over your tone, and then adjust the Drive and Glass to fine-tune the sound once I find it.
The Kanji gives you anything from a gigantic warm clean boost, to creamy sustain on the neck pickup that goes on for days, to edgy classic rock tones. Although, as stated above, this pedal needs a bit of tweakage, but once you learn how to control the pedal, you can coax a lot of different sounds out of it. This is a very versatile Overdrive pedal.
Byten: One Control BBOD, One Control Honey Bee, Fulltone Octafuzz, Voodoo Lab Proctavia, boss dc-2
20 Jan 2019, 10:32
Users browsing this forum: Google [Bot] and 47 guests
