View unanswered posts | View active topics It is currently 27 Aug 2026, 01:49
Reply to topic  [ 5 posts ]
Beta Harp
Post Beta Harp
<font color="brown"></font id="brown"><font color="blue"><font size="3"><font face="Comic Sans MS"><font size="2">Har haft en del kontakt med Ben Bohman som modifierar Sydel 1847 till sina egna Beta Harp spel. Så här kommer lite mer info från honom<b></b>. [:)]
Ligger en översättning om du skrollar ner. </font id="size2"> </font id="Comic Sans MS"> </font id="size3"> </font id="blue">
http://www.beta-harps.com
http://www.harmonicainstituut.nl
http://www.marble-amps.com
http://www.harmonicaheaven.nl
I use the Seydel 1847 as my basic model for customizing because of several
reasons..
The reasons are:
- The wood doesn't swell because the comb is sealed with a clear lacquer
- The front of the teeth of the comb are rounded and have 3 layers of
lacquer on it for more comfort
- The stainless steel reeds do not corrode and last longer/stay better in
tune ( i have prototypes that I built 5 years ago that I still play during
my gigs!)
- The covers are made of stainless steel...do not corrode...and the back of
the covers are opened for better sound projection
- The reedplates are connected to the comb with stainless steel screws
- The combs are flat because they are laser cut/sanded
My basic custom set-up is:
-I round all corners of the reedplates, I make the front edge of the
reedplate smooth/rounded for more comfort
- I emboss the reedslots with 2 different handmade tools... I overemboss the
reedslots a little and clear the edges again with a diamant coated sanding
strip...
- After that I curve all reeds to a set-up that a customer fits...than I gap
all reeds.
- Next is the retuning to the Seydel tuning scheme as can be found on:
http://ohw.se/hca/tntheory.php on tabel 8A
- tuning/checking/retuning/checking/retuning/checking...final check ..this
takes 2 weeks to make sure the tuning stays like it is..
- for overblow set-up I do more detailed work on the reeds to make them more
responsive.
The reason behind all this is I was asked to work for Seydel a few years
ago. They knew me from what I did to my own harps and they had to find a way
to get back into the scene .The factory was broke and 4 new owners decided
to build it up again. So i went every month for a week or so to the factory
and checked the quality, made some changes in the setting up, we used
another tuning ( see above), introduced the steel reeds, trained the
workers, did a lot of tests etc etc...the rest is history!
At the moment I inform the factory when I see a change in quaility, give
them some advice and try to help them any way I can..
I'm thinking of introducing a model 3 beta-harp...which has improved
reedprofiles, all done by hand . This is a 6 hour job + a few weeks of
carefully retuning/setting up the reeds..
The price will be around 250 euros with a lifetime guarantee/service
From this moment on I also offer a Beta-mini ...it is the Seydel Big Six
turned into a custom harp... price 55 euro...not yet on the website but it
can be ordered already.
I hope this is enough for the moment.... :-))
thanks for your help
warm regards
Jag använder SEYDEL 1847 som min grundmodell för anpassning på grund av flera
skäl ..
Skälen är
- Virket inte sväller eftersom kammen är förseglad med en klar lack
- På framsidan av tänderna på kammen är rund och har 3 lager av
lack på det för mer komfort
- De rostfria vass inte korroderar och håller längre / bo bättre
tune (Jag har prototyper som jag byggt 5 år sedan som jag fortfarande spelar under
my gigs!)
- Det täcker är tillverkade av rostfritt stål ... inte korroderar ... och på baksidan av
täcket öppnas för bättre ljudprojektion
- Det reedplates är anslutna till kammen med rostfria skruvar
- Det kammar är platt, eftersom de är laserskurna / slipad
Min grundsyn anpassade uppsättning är:
-I runda alla hörn reedplates, gör jag framkanten av
reedplate slät / rundade för mer komfort
- Jag emboss den reedslots med 2 olika handgjorda verktyg ... Jag overemboss den
reedslots lite och rensa kanterna igen med en diamant belagd sandning
strip ...
- Efter att jag kurva all vass till en set-up som en kund passar ... än jag gap
all vass.
- Nästa är retuning till SEYDEL tuning system som kan hittas på:
http://ohw.se/hca/tntheory.php om tabel 8A
- Tuning / kontroll / retuning / kontroll / retuning / checking...final kolla här ..
tar 2 veckor för att försäkra att trimma förblir som det är ..
- För overblow uppsättning jag göra mer detaljerade arbetet vassen att göra dem mer
lyhörd.
Orsaken bakom allt detta är jag ombads att arbeta för SEYDEL några år
sedan. De kände igen mig från vad jag gjorde med min egen harpa och de måste hitta ett sätt
att komma tillbaka in på scenen. Fabriken var pank och 4 nya ägarna beslutade
att bygga upp den igen. Så jag gick varje månad för en vecka eller så att fabriken
och kontrolleras kvalitet, gjort vissa ändringar i upprättande, använde vi
annan inställning (se ovan), införde stål vass, utbildad i
arbetstagarna, gjorde en massa tester etc etc. .. resten är historia!
För tillfället kan jag informera fabriken när jag ser en förändring i quaility, ge
dem några råd och försöka hjälpa dem på något sätt jag kan ..
Jag funderar på att införa en modell 3 beta-harpa ... som har förbättrats
reedprofiles, allt gjort för hand. Detta är en 6 timmars jobb + ett par veckors
noggrant retuning / inrättande vassen ..
Priset kommer att vara omkring 250 euro med livstids garanti / service
Från denna stund jag också erbjuda en Beta-mini ... det är SEYDEL Big Six
förvandlats till en anpassad harpa ... Pris 55 € ... ännu inte på hemsidan men
kan beställas redan.
Jag hoppas att detta räcker för tillfället .... :-))
Tack för hjälpen
Varma hälsningar
Ben Bouman
Mcool
17 Nov 2009, 15:22
P.S
Har inget att invända mot Ben Boumans moddning, men vet att Dick gör samma arbete samt lite till + att man då får Dicks egendesignade kropp som borde hålla för evigt och har helt andra features än seydels kropp.
Om rostfria tungor håller håller för evigt, vilket vi inte vet så håller Dicks kam lika länge.Priset ligger väldigt lika för vilket man väljer.Dock vet jag inte om någon känner för eller kan byta rostfria tungor eftersom dessa även har rostfria nitar också.Att byta mässingstungor är dock lätt.Vad man väljer blir ju ofta efter personliga preferenser.
17 Nov 2009, 17:40
Såg senare att Ben sätter i rostfria skruvar vilket förstås underlättar tungbyte.Dick sätter även han i skruvar i sina spel.Dick får gärna invända om saker har förändrats.
17 Nov 2009, 17:56
Skulle precis nämna det, men du han före [:D]
Mcool
17 Nov 2009, 18:47
Hej alla,
Jag får tillstå att jag har varit dålig på att marknadsföra mina customspel, om än jag säljer sådana lite varstans i världen. Jag bygger för tillfället spel till Finland, till Tysklad och USA. Och inte minst custom kroppar med resonatorer av silver och kompressionsklackar. De enda som finns för övrigt, tills någon kanske kommer på hur de tillverkas och förstår finessen med dem och kanske plankar dem. Det får jag leva med om det blir så. Avseende mina customspel MB såväl som GM alternativt Hering Vintage, ser mitt arbete ut som följer.
<b>Kåpor</b>
Ventilerade kortändar med unik design.GM
Förstorade öppningar i kåporna baktill, båda kåporna.
Planslipade anliggningsytor mot kroppen
Polerade
MB moddade med Filisko moddning av undre kåpan
<b>Kropp</b>
Valfritt träslag, ex vis Rio Jacaranda, Pink Ivory alternativt kompositträ.
Samtliga kroppar utrustade med resonatorer i sterling silver.
Kompressionsklackar i samtliga kamspår.
Koniskt formade öppingar för högre lufthastighet.
Kropparna lackade 4 till 6 ggr. "Harley Davidson" känsla.
Hög finish
<b>Plattor</b>
Tungor och plattor avstressade genom avspänning (0 spänning)
Skruvade tungor med rostfri skruv (option)
Specialfilade spår i plattorna för ökad respons
Komprimerade spår med agna verktyg som kan köpas separat och som möjliggör att komprimera hela spårets längd utan att demontera tungorna.
Glappet vid nit ställt till 0.02 mm med specialverktyg som även kan köpas separat.
Reed gapping ställt till optimal respons
Reed curvature perfekt ställd med unik overblow metod (min egen)
Polerade tungor
Stämt i stämfixtur (Pro-Tuner) med mkt hög precision med analog Conn strobo tuner. Equal tuning sker med Peterson Strobo Soft.
Den speciella metoden jag använder för avstressning av tungor och plattor innebär omedelbar och över tiden hållbar "sättning" av tungorna, dvs när de är stämda, så håller sig stämningen perfekt under en lång tid.
Jag har säkert glömt andra viktiga detaljer såsom det jag gör på spårens baksida, nämligen att vinkla spåren 15 grader för att kunna viska i spelet och få direkt respons. Men i stora drag är detta vad som händer på mina custom spel.
Sjoeberg
17 Nov 2009, 19:05
