View unanswered posts | View active topics It is currently 22 Oct 2026, 17:52
Xvive W2 Overdrive Fuzz (TRADERA)
Post Xvive W2 Overdrive Fuzz (TRADERA)
http://www.tradera.com/item/301966/234961993/xvive-w2-overdrive-fuzz
Overdrive Fuzzpedal med Blend. Helt ny i förpackning. Kom aldrig till pedalbordet. Nu är det dags att rensa lite.
Vill du höra lite hur den låter så ta och kolla :
Glenn Delaune
https://www.youtube.com/watch?v=5CF52fjS-5Y
Overdrive and Fuzz in one with adjustable blend Bass and Treble Control
Dynamic Response Control
Wide range of effects possible - including
Extremely long sustain fuzz, with a wide range of
tonal adjustability
Tube-like overdrive with gain adjustable from soft
distortion to a screaming, highly compressed
overdriven tube amp sound.
Simple, easy to use design
True Hard Wire Bypass
“effects on” indicator light
Original XVIVE tone – USA Design
Durable all-metal housing
Jag tackar som alltid
Phreakish
19 Jun 2015, 13:59
