View unanswered posts | View active topics It is currently 06 Nov 2026, 09:47
Roland Vk7 Combo Organ (TRADERA)
Post Roland Vk7 Combo Organ (TRADERA)
http://www.tradera.com/item/210403/234949553/roland-vk7-combo-organ
En kämpe som gett mig ordentligt med riktigt schyssta toner men nu ska det byggas om så nu får hon komma till någon som har plats. Riktigt nice 60's eller 70's sound.
Combo organ with "Virtual ToneWheel" technology—91 voices in constant independent oscillation
Full polyphony over the entire 61-key range, eliminates negative effects of phase shifted overtones at the same pitch
COSM-based rotary speaker effects with independently adjustable rotating speeds for horn and rotor
Vibrato, chorus, reverb and amp overdrive effects built in
Classic organ click noise and leakage sound can be added as desired
26 orchestral voices to supplement organ sounds
11-pin rotary cabinet connector for connecting to an external rotating speaker
9 drawbars, dedicated sound selection buttons and a backlit LCD for intuitive control
Alltid tacksam
Phreakish
19 Jun 2015, 13:53
