View unanswered posts | View active topics It is currently 24 Apr 2024, 21:36
Eminence Texas Heat 8 ohm SÅLD
Post Eminence Texas Heat 8 ohm SÅLD
Eminence Texas Heat 8 ohm 12"
Köpt ny av mig augusti förra året. Aldrig använd och helt i nyskick.
En grym högtalare för rock, blues, AC/DC, Led Zeppelin. Väldigt allround. Jag har två Texas Heat i en Marshall 2x12:a och det är min go-to låda.
SÅLD
Från Sweetwater:
12" guitar speaker with smooth, warm tone
Very touch-sensitive, will capture the nuances of your playing
Rich midrange with a bit of top-end bite, suitable for classic rock, blues, and southern rock
SPECIFICATION
Nominal Basket Diameter 12", 305 mm
Nominal Impedance* 8 Ω
Power Rating*
Program Power N/A
Watts 150 W
Resonance 79 Hz
Usable Frequency Range 70 Hz - 4.7 kHz
Sensitivity* 99.4 dB
Magnet Weight 38 oz.
Gap Height 0.31", 7.9 mm
Voice Coil Diameter 2", 51 mm
Länk http://www.eminence.com/speakers/speake ... Texas_Heat
högtalare, 8 ohm, 12 tum, 12"
27 Aug 2018, 11:16
Post Re: Eminence Texas Heat 8 ohm 150 watts 12"
Bump! Inklusive frakt ju...
14 Sep 2018, 16:49
Users browsing this forum: Bing [Bot] and 17 guests
