View unanswered posts | View active topics It is currently 25 Apr 2024, 14:17
Q-Pickups PAF set
Post Q-Pickups PAF set
Det här är riktigt vintage och lite för bright för mig och gitarren, mycket sträng och definition så har du en gitarr som är mörk i tonen så kan det vara rätt. Hade jag osinligt med resurser skulle dom få stanna.
Mycket tekniskt här, blablabla:
Bridge and neck pickup, PAF specs, Cream butyrate bobbins under RAW nickel silver covers.
Built to deliver - hotter wound bridge @ 8kOhm and low wound neck @7kOhm will produce all of those great humbucker tones without getting muddy or microphonic.
These pickups are NOT wax potted.
- non plated nickel silver covers - raw bare U.S.A. made nickel silver cover - NOT POLISHED - may show minor scuffs and scratches.
- wound with plain enamel Elektrisola AWG 42 wire
- stamped nickel silver baseplate with 49.2 mm - 1 15/16" pole spacing for both pickups, long legs, threaded pole screw holes enable contact between the pole screws and baseplates like in the original PAF pickups
- vintage reproduction cream butyrate bobbins with offset square inside hole for slug side bobbin, black lead wires, mismatched DC resistance
- rough cast Alnico 4 magnet bars
- nickel plated steel screws and slugs
- maple spacer
- machined humbucker keeper bar
- single conductor shielded wire with tinned braided copper shield
- brass phillips bobbin mounting screws
- coils and pickups are wraped with 50`s style black paper "flat-back" tape, 1/4" wide
bneostman@live.se
18 Oct 2017, 10:35
Post Re: Q-Pickups PAF set
Pris brukar vara bra :mrgreen:
18 Oct 2017, 14:49
Ja det är det! 1400 :-
bneostman@live.se
18 Oct 2017, 14:53
