View unanswered posts | View active topics It is currently 25 Apr 2024, 18:05
Reply to topic  [ 9 posts ]
Stämapparat Korg GT 120 - SÅLD
Post Stämapparat Korg GT 120 - SÅLD
Stämapparat Korg GT 120 i bra skick.
(Pris: 250:-)
Nytt Pris: 150:-
SÅLD!
Beskrivning:
The Korg GT120 is a guitar and bass tuner that combines the accuracy of needle-type meters with superior functionality and a new, easy-to-use design. The needle-type meter that has enjoyed enduring popularity for its clear visibility and stable detection is now available in a handy size, with the meter located at the top of a sleek black aluminum body. The backlit LCD screen also shows the calibration setting, flat mode, note name, and the remaining battery life. Flat (b) and sharp (#) LEDs light to indicate pitch drift or perfect tuning in a way thats easily visible even on a dimly lit stage. A large dial makes it easy to choose the mode you need to use. Using the stand located on the back, you can conveniently plthe GT-120 upright on your amp or other surfwhile practicing. Model # KOR GT120 RS Features: Dedicated chromatic tuner for guitar and bass that supports seven-string guitars and six-string basses. Dual display combines a needle-type indicator with an easy to read backlit LCD screen. Choose from two tuning modes: Auto or Manual. Built-in reference tone plays in a 5 octave range. Flat Tunings: 1-4 in half-note steps. Item Dimensions: 5.75" L x 3.75" W x 2.5" H
23 Feb 2019, 22:37
Post Re: Stämapparat Korg GT 120
Nytt pris BUMP!
13 Mar 2019, 20:27
BUMP! Ingen som är intresserad av en bra stämapparat?
03 Apr 2019, 20:19
Nytt pris BUMP!
19 May 2019, 19:29
Jag hugger gärna den där!
22 May 2019, 16:48
Är du fortfarande intresserad så finns den kvar? Har av någon anledning inte fått notifiering på denna annons.
05 Aug 2019, 13:46
Jag tar den om den finns kvar....
Mvh
Micke
05 Aug 2019, 14:26
Någon som är fortfarande är intresserad (verkar som att OddBeat har ångrat sig)?
16 Aug 2019, 17:51
Post Re: Stämapparat Korg GT 120 - SÅLD
SÅLD!
18 Aug 2019, 20:00
