View unanswered posts | View active topics It is currently 29 Oct 2026, 13:55
Marshall JCM600 Combo
Post Marshall JCM600 Combo
Funderar på att avyttra en Marshall JCM600 Combo (1x12). Så jag tänkte kolla om det finns nåt intresse för denna samt vad man kan få för den i så fall. Den är i bra skick, footswitch finns.
Så här ser den ut:
Klipper in lite info från Marshalls hemsida:
<ul><li>Valve power from 2x Svetlana EL34 power valves and 4x ECC83 [12 AX7] pre-amp valves.</li><li>Two totally independent channels 'Clean' and 'Overdrive'.</li><li>Separate Treble, Middle and Bass controls for each channel.</li><li>Separate Reverb controls for each channel.</li><li>Master Presence control on the rear panel.</li><li>Series and Parallel Effects Loops with front panel rotary Mix control for the Parallel Loop.</li><li>XLR D.I. output with Marshall Speaker Emulation.</li><li>Marshall Celestion 'Heritage' speakers in the 601 and 602 combos.</li></ul>
04 Sep 2008, 20:01
