View unanswered posts | View active topics It is currently 24 Oct 2026, 18:38
Fender custom shop ”57” amp (2007)
Post Fender custom shop ”57” amp (2007)
Jag har en Fender custom shop 57 till salu.
COA-boken (intyget) finns med. 300 tillverkade. Låter fint.
25000:-
Stärken bor i Stockholm.
FEATURES
Hand-wired all-tube circuitry on eyelet board
Late 1950s 5E3 circuit produces about 12 Watts
Matched pair of Groove Tubes GT6V6 output tubes
5Y3 rectifier tube contributes to compression and “sag” when amp is played hard
Two 12AX7 preamp tubes, one of which may be substituted with a 12AY7 for the original ’50s lower-gain sound, if desired
Mic and Instrument channels; Each channel has individual volume controls and High & Low inputs
12″ Celestion Alnico Blue speaker
Dovetail-joined solid Maple cabinet
Black “Piano Lacquer” finish
Holographic diamond-cut “57″ badge on front of amp; “One of only 300″ badge on rear panel
Premium heavy-knurl “Roll-Easy” Telecaster knobs with engraved “57″ logo
Solid aluminum speedboat handle; metal hex-head screws throughout
Blue jewel light
SPECIFICATIONS
’57 Combo Amp
Type: Tube Amplifier
Output: 12 Watts
Ohms: 8 Ohms
Speakers: One 12 Inch Celestion Alnico Blue Speaker (P/N 007-3313-000)
Channels: Two (Instrument And Microphone)
Tubes: 2-12AX7, 2-GT6V6, 1-5Y3
Weight: 36 Lbs (16.3 Kg)
Dimensions:
Height: 18.75″ (48 Cm)
Width: 20″ (51 Cm)
Depth: 9.5″ (24 Cm)
09 Feb 2022, 22:10
