| Revv D20 http://ljudbojen.com/viewtopic.php?f=25&t=127744 |
Page 1 of 1 |
| Author: | Supreme [ 05 Apr 2021, 21:04 ] |
| Post subject: | Revv D20 |
Hej Fundera på att sälja min Revv D20 topp. An inspiring all-tube clean & crunch amp with Two notes Torpedo-Embedded reactive load & virtual cabinets. All tube. ~9lbs. 20 or 4 watt operation. World-class clean & crunch tones developed with Nashville session greats. Two notes reactive load & virtual cabinets built in. FXLoop, MIDI, & more. Buld your own rig with amp-voiced pedals for high gain. Traditional, cabless, or hybrid. Recording, live, & home. D20 has you covered. Overview The D20 is the world’s first Two notes Torpedo-Embedded amplifier. This all-tube head has an optional reactive load for organic feel & tone when playing without a cab & hosts virtual cabinets onboard for direct recording, silent playing, & live performance without a microphone. We set out to build an amp that not only has this new modern featureset but sounds incredible on its own as a standalone amplifier. The result is something convenient & great sounding at the lowest price point Revv has ever had. Features Inspiring Clean & Crunch tones developed with Nashville sessions guitarists Perfect platform for your favorite gain pedals 3-band EQ + Volume & Gain controls Push/Pull gain pot for 2nd crunchier voicing Switchable from 20 to 4 watts 2 6v6 – 2 12ax7 Buffered Series FX Loop Switchable 4/8 Ohm speaker jack Embedded Two notes Reactive Load & Virtual Cabinets Go direct to Front of House, interface, or headphones – without a cabinet. Hundreds of virtual mics, speakers, cabinets, EQ, reverb, & more available. XLR Balanced Direct Output, USB, & Ground Lift for Torpedo Embedded 6 Pre-Loaded Virtual Cabinets selectable via front knob – all customizable. Or up to 128 via MIDI. “Pre & Post” switch selects whether (in reactive load direct mode only) the power amp is in the signal chain. This is so you can take advantage of Two notes’ power amp simulation & dramatically change the character of the D20 with virtual tubes such as EL84, if you like. Reactive Load automatically engages when speaker is not detected to preserve amp Select Between Internal & Speaker Load Level-Adjustable Headphone Out Small, Light, & Durable 6.3125″x7.5″x12.3125″ including knobs, not including handle High Quality Transformers Easily Accessible Rear-Bias Test Easily Accessible Fuse Durable, Lightweight Aluminum Enclosure Weighs ~9lbs LED-Illuminated Badge Kan skickas emot fraktkostnad Pris 8900kr |
