Galaxy Combo från Supro är en rördriven 50 W combo med 2 kanaler, rördrivet reverb och rördriven effektloop.
2-channel, all-tube design. High-headroom Clean channel. Overdrive channel with 3-band EQ. Master Volume on high-gain channel only. Switchable Boost works on both channels. All-tube buffered Effects Loop Wattage: 50 Watts Class AB. Speaker: 1x12" Eminence CV75. Preamp Tubes: 4x ECC83S, 1x ECC81, 1x ECC832. Power Tubes: 2x 6L6GC / 5881. 1x12 Combo Weight: 50lbs 1x12 Combo Dimensions: 20.3" x 8.7" x 18" Tolex: Black Leatherette with Suede Accent. Assembled in New York, USA.
