2 st Eminence GB128 (typ Greenbacks) SÅLT
2 st Eminence GB128 8 ohm säljes. De låter verkligen som Greenbacks men med lite fastare bas (och högre volym), iallafall när jag jämför med min Marshall 1960BX-låda. Prima skick! Precis inspelade ca 30 timmar. Specs:
Quote:
If you're looking for that classic British sound, this is the speaker to have. This Eminence speaker will provide a warm low end and plenty of punch, and all the tonal characteristics embraced by many legendary guitar players. 8 ohm. 50W RMS.
Impedance: 8 ohms Power Rating: 50W Maximum Power: Frequency Response: 80Hz-5.1kHz Voice Coil Diameter: 1.75", 44.5mm Depth: 6.06", 154mm Coil Construction: Copper voice coil Magnet Composition: Ferrite magnet Cone composition: Paper Cone Nominal Basket Diameter:12", 304.8mm Sensitivity: 101.4 Magnet Weight: 38 ounce Core Details: Non-vented core Coil Former: Paper former
