SOLD ##### Komet 50 limited
Komet 50 limited edition (Concorde) tweaked by Ken Fisher (Trainwreck), SUPER RARE!
Komet Amplification is proud to introduce the highly anticipated Komet Limited. The Limited incorporates a new circuit designed by Ken Fischer, and as a tribute to this legendary amp designer; the Limited honors the classic Trainwreck tradition of having a solid hardwood cabinet. The cabinet is hand crafted from exotic African Bubinga, with a contrasting flame maple V front and is finished to the quality of fine furniture.
The new Trainwreck designed circuit as well as Ken's specially designed power and output transformers; offer a new sound for this model. Unlike the Komet 60, Ken designed the Limited to operate exclusively with EL 34 power tubes. This allowed him to design the circuit and transformers as well as select each component to get the very best from EL34 tubes without any compromises. The amp has more gain than Ken’s other designs for Komet and incorporates a solid state rectifier. The Limited offers benchmark EL 34 tone with rich complex harmonics, creamy rhythms, and singing leads, all reinforced with a strong, bold, tight, low end bass response.
Traditional Trainwreck principles are followed in the design and construction. The Limited is a single channel amp and does not have reverb, master volume, effects loop, foot switches, pull pots, transistors, chips or anything else that degrades tone, harmonic complexity or touch sensitivity. Like all Komet amplifiers the chassis is solid 1/8” welded aircraft grade aluminum and only the finest components are used.
The custom cabinet is a work of art and is hand crafted out of exotic African Bubinga incorporating half blind dovetail joints, creating a strong bond which also adds a decorative touch. A one piece flame maple " V " details the signature Komet motif. The cabinet is solid heirloom quality hardwood including the amps back panel and is finished superbly.
*The controls, switches and jacks are enhanced by custom gold, anodized front and back control panels. A precision 10-turn bias control, bias test points and a *Fast - Gradual *switch are included on the amp.
More info:
http://www.ultrasoundampsales.com/amp_b ... hp?ampid=545.000 SEK (Komet Airbrake, Komet Power attenuator can be included)
