View unanswered posts | View active topics It is currently 23 Sep 2026, 08:04
Reply to topic  [ 5 posts ]
Tuners + Bigsby LP Std 61
Post Tuners + Bigsby LP Std 61
Postar detta här också, om någon har förslag eller sitter på gamla eller nya Bigsby delar så hör av Er.
Även intresserad av en gammal tuner , dubbelring, enkelradig Kluson , bara hus eller med plastvred i bra skick.
Kommer hålla ögonen öppna på mässan också.
postat på LPF
Hi,
I am having thoughts on IF and what to do to the following issues on my 61 Lp Standard , it is an original Bigsby equipped guitar:
Bigsby
1 The handle, bracket, roller and spring is missing. The roller is replaced with a shorter one with holes instead of the 'spikes' so no bracket can be added , it looks the same in both ends as the normal bigsby does on the 'no bracket side' if that makes sense ?
What to do ?
A Leave it.... (works fine, except for that tremolo stuff..)
B Try to get vintage parts, doesnt seem easy to find and buying a vintage B5 to butcher it is not my intention
C Get a modern B5 unit , take the parts I need and age them like I did on my 61 reissue... I THINK they would fit , unless the size of the holes for the roller in the new unit are different?
Tuners
It has had a set of different tuners at one point, and now has a set of RS aged double ring single line tuners on. The originals are in the case with the following status:
2 perfectly fine ....
1 tip brown but stil intact
1 tip brown started to break
1 Tip broken and gone
1 70´s .....
My problem is that I dont like the look of the new ones, both colour and shape is IMHO off...
Specially the tips. No 1 and 3 in the picture are RS. 2 and 4 are the originals.
A Leave it...
B Use the 5 originals + 1 RS housings and get new better looking tips
C Put the 2 originals on mixed with 4 RS
D Since the tuner holes have been enlarged already , put aged Grovers on it.
What Do You recommend?
Other options or thoughts appreciated, however buying a set of 61 tuners in perfect condition or a complete vintage Bigsby would be to expensive...
It still would not be 100% original, so trying to fix this with a little as possible funds.
22 Oct 2012, 12:23
Post Re: Tuners + Bigsby LP Std 61
Jag hade satt ett nytt B5 på den. Aluminium blir fort nermattat vid användning. Den svarta färgen slits också fort. Beträffande stämmissarna skulle jag köpt ett nytt relicat set och sparat de gamla om jag inte hade fått tag på en, eller några gamla.
22 Oct 2012, 12:32
Tack för förslag, angående Tuners så sitter det redan ett 'relicat set' där ... , inget fel på dom eg , men det lyser LITE repro om dessa just på en gammal gitarr , och sätter man orginalskruvarna bredvid så ser man hur det SKA se ut (se bilden)
Just nu i skrivande stund funderar jag faktiskt lite på ett set åldrade Grovers istället , för dom är verkligen NICE från samma leverantör, här på min 61 reissue:
22 Oct 2012, 13:12
Såna där stämmisar har jag. Ett eller till och med två set.
Men frågan är om jag behöver dem eller inte?
22 Oct 2012, 14:28
Exakt såna här? Double ring, single line?
Har ju 5 av dess , 2 är ok , 2 skulle bli OK med super glue och 1 med en ny tip som ser vettigare ut
den som jag skrev '70-tals' på är nog snarare sen 60´s , ser också likadan ut men har 'kluson deluxe' i 2 rader.
F-n vad svårt att bestämma sig , man kanske ska köra på Grovers istället.... å andra sidan kul att ha så pass mycket orginal som möjligt , lackar man dom med superlim så stoppas ju åldersprocessen i alla fall
22 Oct 2012, 15:01
