| Clownburstar http://ljudbojen.com/viewtopic.php?f=21&t=57403 |
Page 1 of 1 |
| Author: | Haraldrig [ 04 May 2011, 22:38 ] |
| Post subject: | Clownburstar |
Är inte sexiga och har man lite tid så kan man åtgärda det. Hade en ful clownburst-pålle från mitten av 70-talet i gömmorna och retade mig som fasiken på hur ful den var. Men nu är det åtgärdat! ![]() ![]() I'll call the cops on my own self, figure out a way to please those men I'll play detective, I'll play bloodhound, sniffing up clues with my nose in the mud |
| Author: | christian-h [ 04 May 2011, 23:04 ] |
| Post subject: | |
När dyker denna upp under säljes då? [:)] Med vänliga hälsningar, <u><i><b><font color="brown">Christian.</font id="brown"></b>"]</u> |
| Author: | Haraldrig [ 04 May 2011, 23:16 ] |
| Post subject: | |
christian-h wrote: När dyker denna upp under säljes då? [:)] Med vänliga hälsningar, <u><i><b><font color="brown">Christian.</font id="brown"></b>"]</u> ungefär aldrig. I'll call the cops on my own self, figure out a way to please those men I'll play detective, I'll play bloodhound, sniffing up clues with my nose in the mud |
| Author: | christian-h [ 04 May 2011, 23:22 ] |
| Post subject: | |
Haraldrig wrote: christian-h wrote: När dyker denna upp under säljes då? [:)] Med vänliga hälsningar, <u><i><b><font color="brown">Christian.</font id="brown"></b>"]</u> ungefär aldrig. I'll call the cops on my own self, figure out a way to please those men I'll play detective, I'll play bloodhound, sniffing up clues with my nose in the mud ok, ok. Med vänliga hälsningar, <u><i><b><font color="brown">Christian.</font id="brown"></b>"]</u> |
| Author: | ChronicTown [ 05 May 2011, 00:41 ] |
| Post subject: | |
christian-h wrote: Haraldrig wrote: christian-h wrote: När dyker denna upp under säljes då? [:)] Med vänliga hälsningar, <u><i><b><font color="brown">Christian.</font id="brown"></b>"]</u> ungefär aldrig. ok, ok. Med vänliga hälsningar, <u><i><b><font color="brown">Christian.</font id="brown"></b>"]</u> Kommersiell verksamhet får ju inte annonsera här, så risken bör vara begränsad. [;)] |
| Author: | glassfinger [ 05 May 2011, 09:41 ] |
| Post subject: | |
Det hade varit trevligt med en bild på hur den såg ut innan. |
| Author: | Mike Leaf [ 06 May 2011, 09:38 ] |
| Post subject: | |
Ännu en våldtagen 70´s Les Paul... [:)] Men visst fan är dom fula. En kille på LPF var proffesionell countrygitarrist , han lämnade sin 58 burst till Gibson i Nashville för lite allmän 'setup' och ombandning 1979. För att vara extra bussiga så lackade dom om den i clown style både fram och bak, slängde i ny hårdvara och mickar. Dom gamla delarna lyckades han rädda , dom låg i caset men lacken var ju inget att göra åt. |
| Author: | lestrange [ 06 May 2011, 15:02 ] |
| Post subject: | |
glassfinger wrote: Det hade varit trevligt med en bild på hur den såg ut innan. Om jag skulle avslöja att den var "grundad" med ett tjockt lager plastic padding, och sedan målad i en hiskelig ljust spygrön metallic, kanske ni förstår att Haraldo är en skojfrisk liten spjuver som narras med er![:D] |
| Author: | Haraldrig [ 06 May 2011, 15:59 ] |
| Post subject: | |
lestrange wrote: glassfinger wrote: Det hade varit trevligt med en bild på hur den såg ut innan. Om jag skulle avslöja att den var "grundad" med ett tjockt lager plastic padding, och sedan målad i en hiskelig ljust spygrön metallic, kanske ni förstår att Haraldo är en skojfrisk liten spjuver som narras med er![:D] Idiot!!! Nu förstör du ju mitt komparativa attitydsexperiment mellan Bojen och Diskant. I'll call the cops on my own self, figure out a way to please those men I'll play detective, I'll play bloodhound, sniffing up clues with my nose in the mud |
| Author: | Gibson55 [ 07 May 2011, 11:58 ] |
| Post subject: | |
Min 78 e rock´n roll , ruggigt snygg och med massor av manlighet[;)] , eller inte , men den sticker ut lite med sina färger.[8D] ![]() ![]() Rookie på det mesta , men glad ändå. |
| Author: | Haraldrig [ 07 May 2011, 12:17 ] |
| Post subject: | |
Customen ser ut att väga typ 5.5kg. Är den tung? Min den väger ca 4.2kg. I'll call the cops on my own self, figure out a way to please those men I'll play detective, I'll play bloodhound, sniffing up clues with my nose in the mud |
| Author: | Gibson55 [ 07 May 2011, 12:38 ] |
| Post subject: | |
Haraldrig wrote: Customen ser ut att väga typ 5.5kg. Är den tung? Min den väger ca 4.2kg. I'll call the cops on my own self, figure out a way to please those men I'll play detective, I'll play bloodhound, sniffing up clues with my nose in the mud Nyvägd enbart för frågan 4,4kg (badrumsvåg) , men jag har en Les paul som väger 5,5!! Rookie på det mesta , men glad ändå. |
| Author: | Haraldrig [ 07 May 2011, 12:43 ] |
| Post subject: | |
Gibson55 wrote: Haraldrig wrote: Customen ser ut att väga typ 5.5kg. Är den tung? Min den väger ca 4.2kg. I'll call the cops on my own self, figure out a way to please those men I'll play detective, I'll play bloodhound, sniffing up clues with my nose in the mud Nyvägd enbart för frågan 4,4kg (badrumsvåg) , men jag har en Les paul som väger 5,5!! Rookie på det mesta , men glad ändå. 4.4 är ganska bra trots allt. I'll call the cops on my own self, figure out a way to please those men I'll play detective, I'll play bloodhound, sniffing up clues with my nose in the mud |
| Author: | Mike Leaf [ 07 May 2011, 21:47 ] |
| Post subject: | |
Haraldrig wrote: Gibson55 wrote: Haraldrig wrote: Customen ser ut att väga typ 5.5kg. Är den tung? Min den väger ca 4.2kg. I'll call the cops on my own self, figure out a way to please those men I'll play detective, I'll play bloodhound, sniffing up clues with my nose in the mud Nyvägd enbart för frågan 4,4kg (badrumsvåg) , men jag har en Les paul som väger 5,5!! Rookie på det mesta , men glad ändå. 4.4 är ganska bra trots allt. tycker du det ? [B)] Bra för mitten 70 -tal kanske |
| Author: | Haraldrig [ 08 May 2011, 00:56 ] |
| Post subject: | |
Mike Leaf wrote: Haraldrig wrote: Gibson55 wrote: [quote="Haraldrig"] Customen ser ut att väga typ 5.5kg. Är den tung? Min den väger ca 4.2kg. I'll call the cops on my own self, figure out a way to please those men I'll play detective, I'll play bloodhound, sniffing up clues with my nose in the mud Nyvägd enbart för frågan 4,4kg (badrumsvåg) , men jag har en Les paul som väger 5,5!! Rookie på det mesta , men glad ändå. 4.4 är ganska bra trots allt. tycker du det ? [B)] Bra för mitten 70 -tal kanske [/quote] För en 78'a Custom tycker jag 4.4kg är ok. I'll call the cops on my own self, figure out a way to please those men I'll play detective, I'll play bloodhound, sniffing up clues with my nose in the mud |
| Author: | CarlM [ 10 May 2011, 19:46 ] |
| Post subject: | |
Konstigt vad idealen förändras. I slutet av 70-talet var ju en cherry sunburst Les Paul den ultimata drömgitarren. Först för att Ace Frehley spelade på en: ![]() sen för att Brian Robertson spelade på en: ![]() och Scott Gorham... ![]() I en värld utan Internet och reissues var det referensen och drömen för alla oss som harvade på med våra japanska kopior som aldrig kändes lika bra som de lättspelade Gibsönerna som man någon gång då och då fick provspela i någon musikaffär, om ägaren var på gott humör. Så det känns lite konstigt när de helt plötsligt kallas "clown burst" och lackeras om för att de anses så fula. Men jag har inget emot att folk moddar och lackar om musikinstrument, Var och en gör vad den vill med sin egendom och tycker man något är fult eller dåligt, så ska man förstås fixa till det. Jag har borrat sönder både en gammal fender och en plexi för att "förbättra" dem. Det kändes rätt då, men i efterhand var det förstås ingen bra idé. /CM |
| Author: | we_made_wor_history [ 12 May 2011, 07:07 ] |
| Post subject: | |
vad är "clown burst"? samma som cherry sunburst bara eller vaddå`? "maybe its not too late to learn how to love and forget how to hate" |
| Author: | steelneck [ 12 May 2011, 10:03 ] |
| Post subject: | |
we_made_wor_history wrote: vad är "clown burst"? samma som cherry sunburst bara eller vaddå`? "maybe its not too late to learn how to love and forget how to hate" Jo, men en form av det, med bl.a. väldigt skarpa övergångar mellan röda och gula, se bild: ![]() Korrekt målade är den färgen dock [:p] |
| Author: | Mike Leaf [ 12 May 2011, 12:24 ] |
| Post subject: | |
_CM_ wrote: Konstigt vad idealen förändras. I slutet av 70-talet var ju en cherry sunburst Les Paul den ultimata drömgitarren. Det är det fortfarande ! men det som jag tror många reagerat på kanske i EFTERHAND är ju att Gibsons sunburst from 1970 var så OLIK de 'riktiga' orginalen från 58-60. Samt att man gav sig på baksidan av kropp och hals också... [B)] Numer tycker jag dessa har sin egen charm, och termen 'clownburst' används inte endast i negativa avsikter tycker jag. Att man skulle lacka om en orginal cherry LP tycker jag är lite synd oavsett vad man tycker om kulören |
| Author: | rifle [ 12 May 2011, 12:32 ] |
| Post subject: | |
Clownburstar gör sig också bättre på foto än i verkligheten där det inte blir samma synliga tydliga effekt. Helst fotat med en dålig digitalkamera i dåligt ljus för absolut bästa effekt. [:o)] |
| Author: | henriperkio [ 13 May 2011, 10:41 ] |
| Post subject: | |
är inte clownburst att den är burst på topp, bak och hals? och sen att det är hiskeliga färgkombinationer.. |
| Author: | Mike Leaf [ 13 May 2011, 13:34 ] |
| Post subject: | |
henriperkio wrote: är inte clownburst att den är burst på topp, bak och hals? och sen att det är hiskeliga färgkombinationer.. Det ena brukar automatiskt inkludera det andra..... |
