| Gammal Hofner / Höfner bas dateringshjälp http://ljudbojen.com/viewtopic.php?f=21&t=21996 |
Page 1 of 1 |
| Author: | benganjimmy [ 11 Dec 2008, 15:53 ] |
| Post subject: | Gammal Hofner / Höfner bas dateringshjälp |
Dateringshjälp av gammal Hofner bas (fiol) önskas,serienr 267. Bilder på vendolin.se. http://www.vendolin.se/Annonce_Detail.a ... id=5527705 BI |
| Author: | Ballz [ 11 Dec 2008, 16:00 ] |
| Post subject: | |
På första träffen på Google (sökord: "dating a hofner violin bass")säger man följande: "Question: Anyone know how to date my Hofner Violin Bass (serial no 1434)? Answer: There is no real way to determine the actual date of a Hofner 500/1. If your bass was made in the 60's then you can do the following. Take the control panel off the bass and look at the two pots on it. They will be marked 250k _ _ _. The 250 refers to the resistance value of the pot and the next 3 numbers refer to the month and year the pots were made. For example 250k 236 means that the pots were made in the 23rd week of 1966. Assembly of the bass in general would have been shortly after that date. " Fem träffar längre ner: "Hofner introduced their violin-shaped bass circa 1955 to limited success. Between 1955 and 1964 fewer than 250 were built. This changed in February 1964 with the appearance of the Beatles on the Ed Sullivan Show, with Paul McCartney using his second lefty 500/1, which he acquired in 1963." Om du har svintur kan du evt hitta en datummärkning på undersidan av locket - använd tandläkarspegel. Gitarrerna märktes ofta så, kanske basarna också, eftersom så få byggdes. /R |
| Author: | benganjimmy [ 11 Dec 2008, 16:27 ] |
| Post subject: | |
Tack för tipsen Ballz, jag ska försöka hitta spegel som går att använda för detta. Mvh BI Ballz wrote: På första träffen på Google (sökord: "dating a hofner violin bass")säger man följande: "Question: Anyone know how to date my Hofner Violin Bass (serial no 1434)? Answer: There is no real way to determine the actual date of a Hofner 500/1. If your bass was made in the 60's then you can do the following. Take the control panel off the bass and look at the two pots on it. They will be marked 250k _ _ _. The 250 refers to the resistance value of the pot and the next 3 numbers refer to the month and year the pots were made. For example 250k 236 means that the pots were made in the 23rd week of 1966. Assembly of the bass in general would have been shortly after that date. " Fem träffar längre ner: "Hofner introduced their violin-shaped bass circa 1955 to limited success. Between 1955 and 1964 fewer than 250 were built. This changed in February 1964 with the appearance of the Beatles on the Ed Sullivan Show, with Paul McCartney using his second lefty 500/1, which he acquired in 1963." Om du har svintur kan du evt hitta en datummärkning på undersidan av locket - använd tandläkarspegel. Gitarrerna märktes ofta så, kanske basarna också, eftersom så få byggdes. /R BI |
| Author: | Haraldrig [ 11 Dec 2008, 19:17 ] |
| Post subject: | |
benganjimmy wrote: Tack för tipsen Ballz, jag ska försöka hitta spegel som går att använda för detta. Mvh BI Ballz wrote: På första träffen på Google (sökord: "dating a hofner violin bass")säger man följande: "Question: Anyone know how to date my Hofner Violin Bass (serial no 1434)? Answer: There is no real way to determine the actual date of a Hofner 500/1. If your bass was made in the 60's then you can do the following. Take the control panel off the bass and look at the two pots on it. They will be marked 250k _ _ _. The 250 refers to the resistance value of the pot and the next 3 numbers refer to the month and year the pots were made. For example 250k 236 means that the pots were made in the 23rd week of 1966. Assembly of the bass in general would have been shortly after that date. " Fem träffar längre ner: "Hofner introduced their violin-shaped bass circa 1955 to limited success. Between 1955 and 1964 fewer than 250 were built. This changed in February 1964 with the appearance of the Beatles on the Ed Sullivan Show, with Paul McCartney using his second lefty 500/1, which he acquired in 1963." Om du har svintur kan du evt hitta en datummärkning på undersidan av locket - använd tandläkarspegel. Gitarrerna märktes ofta så, kanske basarna också, eftersom så få byggdes. /R BI Ta med guran till tandläkaren nästa gång[:)] Min Email: Straponyourguitar(AT)hotmail.com |
| Author: | Thomas [ 12 Dec 2008, 00:30 ] |
| Post subject: | |
Basen på bilden har en bred kontrollpanel som kom 64-65, en Logo i plast som är en egen enhet (inte överlacklad dekal), "staple" pickuper med breda sargar, binding på halsen, kort stränghållare. Det är en 1965-67 års bas. Pot dateringen är inget 100% daterings sätt. Då Höfner hade MÄNGDER med delar liggandes. Det var ju inte bara 500/1 basen som hade dessa delar, nästan alla jazzburkar hade samma elektronik delar etc. Så man kan hitta en 500/1 bas med 64ans elektronik och 65ans andra specar. Serie numret som ofta finns stämplat på huvudets kant är importörens serienummer. Dvs, Höfner själva förde inga register över instrument tillverkade. (Utom de som importerades av Selmer i UK, de fick serienumer på en papperslapp i instrumenten. Lite svårt i 500/1 och 2 basarna.) Men Höfner daterade 99,9% av alla instrument på insidan av locket. Men som sagt jag gissar på -65-67 Före 1965 hade pickuperna tunn sarg, efter 67/68 kom "blade" pickuperna. Det finsn andra som kan mer. Men detta är min gissning. En sak är säker. Det är ingen -63a. -63 modellen hade smal kontrollpanel, ingen binding på halsen, samt dekal logo. Kolla min re-63 som referens ![]() Ett enkelt sätt att kolla det handskrivna datumet är att lossa på kontrollpanelen samt utgångs jacket... Lys ner med en ficklampa i hålet för kontrollpanelen och titta genom hålet för jacket. Då kan man se datumet, 90% av alla gånger står det under bassidan av stallet. Samt som Ballz skrev, "pot-kollen". först värdet på poten 250k, sedan tre siffror. Sedan vecka och år. Visst det kan vara 1959 och 1969, men då finns miljoner andra saker man kan kolla på för att bestämma vilket år. Bara genom att titta på den så kan man bestämma ungefär ner till 2-3 år fel. Efter det får man kolla närmare när det gäller fin liret på datumet. Det såldes två Höfner 500/1 basar på tradera nyligen bägge ca -65or, samt de gick för ca 7-8000 kronor. Som sagt, det finns de som kan betydligt mer. Jag är bara en amatör. Jag mailade dig benganjimmy för ett bra tag sedan men inte fått något svar. Mailet kanske inte kom fram?... "the man who put the 'ow' in 'Hofnerhownds'" Neil -06 |
| Author: | benganjimmy [ 12 Dec 2008, 08:50 ] |
| Post subject: | |
Hej Thomas Tack för svaret nu tror nog jag att jag kan klara av dateringen av basen.Ljudbojens mejl funktion funger bara ibland har vi märkt. Tack och ha det bra. Mvh BI Thomas wrote: Basen på bilden har en bred kontrollpanel som kom 64-65, en Logo i plast som är en egen enhet (inte överlacklad dekal), "staple" pickuper med breda sargar, binding på halsen, kort stränghållare. Det är en 1965-67 års bas. Pot dateringen är inget 100% daterings sätt. Då Höfner hade MÄNGDER med delar liggandes. Det var ju inte bara 500/1 basen som hade dessa delar, nästan alla jazzburkar hade samma elektronik delar etc. Så man kan hitta en 500/1 bas med 64ans elektronik och 65ans andra specar. Serie numret som ofta finns stämplat på huvudets kant är importörens serienummer. Dvs, Höfner själva förde inga register över instrument tillverkade. (Utom de som importerades av Selmer i UK, de fick serienumer på en papperslapp i instrumenten. Lite svårt i 500/1 och 2 basarna.) Men Höfner daterade 99,9% av alla instrument på insidan av locket. Men som sagt jag gissar på -65-67 Före 1965 hade pickuperna tunn sarg, efter 67/68 kom "blade" pickuperna. Det finsn andra som kan mer. Men detta är min gissning. En sak är säker. Det är ingen -63a. -63 modellen hade smal kontrollpanel, ingen binding på halsen, samt dekal logo. Kolla min re-63 som referens ![]() Ett enkelt sätt att kolla det handskrivna datumet är att lossa på kontrollpanelen samt utgångs jacket... Lys ner med en ficklampa i hålet för kontrollpanelen och titta genom hålet för jacket. Då kan man se datumet, 90% av alla gånger står det under bassidan av stallet. Samt som Ballz skrev, "pot-kollen". först värdet på poten 250k, sedan tre siffror. Sedan vecka och år. Visst det kan vara 1959 och 1969, men då finns miljoner andra saker man kan kolla på för att bestämma vilket år. Bara genom att titta på den så kan man bestämma ungefär ner till 2-3 år fel. Efter det får man kolla närmare när det gäller fin liret på datumet. Det såldes två Höfner 500/1 basar på tradera nyligen bägge ca -65or, samt de gick för ca 7-8000 kronor. Som sagt, det finns de som kan betydligt mer. Jag är bara en amatör. Jag mailade dig benganjimmy för ett bra tag sedan men inte fått något svar. Mailet kanske inte kom fram?... "the man who put the 'ow' in 'Hofnerhownds'" Neil -06 BI |
