View unanswered posts | View active topics It is currently 22 Sep 2026, 12:41
Knopp till svajarm
Testa på GMF eller Gitarrdelar.se. De kostar bara några kronor.
http://www.gmf.se
http://www.gitarrdelar.se
Mvh / Janne
<font color="green">If you can bend it you can mend it, if you can't mend it don't bend it - just make shure it's a Fender, Bender!</font id="green">
28 Jun 2008, 21:10
